It is currently Sat Sep 13, 2025 4:10 pm
PostPosted: Thu Jan 31, 2008 11:41 am
I recently was an a hardwood supplier and found a nice piece of African Blackwood. The problem was there were a few checks on the one end of the board. Can this be easily repaired or is this a bad idea? Can Blackwood cracks be "filled" similar to Ebony (CA/epoxy and dust)?
Brad
Avon, OH
PostPosted: Thu Jan 31, 2008 1:58 pm
What do you want to do with it?
PostPosted: Thu Jan 31, 2008 8:53 pm
I would like to resaw it into a few back and side sets. It is in good condition and since it is 37" long and I could probably work around the imperfections. HOWEVER, if there are a few minor problems I just wanted to know how repairable it is.
Thanks!
Brad
Avon, OH
PostPosted: Fri Feb 01, 2008 3:47 am
Small voids in AB can be filled almost invisibly with sawdust and epoxy. What those checks might mean for the long term stability of the panels you resaw is another question, but usually it is a fairly stable wood after it has dried.
PostPosted: Fri Feb 01, 2008 4:48 am
African Blackwood can be very hard on tools such as bandsaw blades and such and you will want to make sure your bandsaw blade is sharp when you start resaawing that stuff.
Users browsing this forum: Kbore and 13 guests
